A couple of my buddies are trying to bleed the system. They are doing everything by the book, raising the rear, bleeding through that bolt, then moving to the bleed bolt on the carb shutoff. Their problem is that there is no coolant coming out of that bleed bolt!? They have coolant everywhere they need it(in the carbs, head, heat exchanger, etc.), and the sled is not running hot, so any idea why they cannot bleed through that bolt?
Thanks,
Focker
Thanks,
Focker
