TimeBomb
finally pulled the trigger on a leftover 09 sx230ho. i told my dealer i'd take it and hes going to hold it for me until april/may. i'm hoping to sell my viper and waverunner so i can put some cash down on it. its going to be a long couple of months.
here she is http://www.yamaha-motor.com/boat/products/modelimagelib/421/3/3/0/image.aspx
just sitting in the warehouse waiting for me
here she is http://www.yamaha-motor.com/boat/products/modelimagelib/421/3/3/0/image.aspxjust sitting in the warehouse waiting for me
anchor
3000lb! dry weight. Have you ever been in one? I bet it is a nice and slow ride.
TimSRX
True, no speed boat like the other Yamaha Jet Boats, but my guess is that it is still a 40-40mph boat, which in my eyes is plenty fast. My 20' Grady White does 40mph on a good day, and for me and my wallet, is plenty fast. Can't do much about the weight through, should do great in a nice chop.
TimeBomb
i've read top speed is 50. don't care about speed.
no1chevyboy
hope your going to run in deep water, jets suck in shallow
Ran my exciters everywhere. Bullet proof!! Very dangerous with many beers. Be careful.
TimeBomb
not looking to drink out on the water.
isn't the idea of jets so you can run in shallow water if you want?
ryanryan
TimeBomb said:not looking to drink out on the water.
Shallow as in rocky, yes. Shallow as in sandy, hell no.
grapeape
If you need to go over 50, my ls2000 will be for sale in the spring. Shallow water, look at the 18pg thread in the general section of yamahajetboaters.com The guy ran it untill it bottomed out in 4 in of water, no damage, got lucky that Texas had all the flood problems last fall and was able to get it out.
TimeBomb
yeah i saw that on there. she was stuck
onewickedr1
Nice boats, rock solid bullet proof. Typically they are faster than that but it looks like you will be able to bring a few friends... which will help w/gas money. Those things are thirsty! Just look out for birds standing ontop of the water... long story.
no1chevyboy
they are no good for shallow water at all unless its over clean concrete,for one you will plug the cooling system up going thru mud. sand, sand will wear out the drive prop and ring like sand blasting with water,rocks will destroy the prop and ring, weeds will plug water pick up, swallow water is a myth and selling point that is untrue.just an example i was tuneing a jet ski in three ft of water and it was sucking pee gravel from the bottom.all season we are repairing them from people thinking they can run in shallow water this is a myth! the only time there is a chance you could run in shallow water and not damage anything is if you go from deep to swallow like a sand bar at wot up on plain.
ryanryan
no1chevyboy said:they are no good for shallow water at all unless its over clean concrete,for one you will plug the cooling system up going thru mud. sand, sand will wear out the drive prop and ring like sand blasting with water,rocks will destroy the prop and ring, weeds will plug water pick up, swallow water is a myth and selling point that is untrue.just an example i was tuneing a jet ski in three ft of water and it was sucking pee gravel from the bottom.all season we are repairing them from people thinking they can run in shallow water this is a myth! the only time there is a chance you could run in shallow water and not damage anything is if you go from deep to swallow like a sand bar at wot up on plain.
When I said shallow as in rocks I meant like big, big rocks. Such as jumping rapids, which is one of the main purposes for a jet-boat.
TimSRX
This boat is fiberglass, if you hit anything hard you'll do damage. That's why the river boats made for hitting rocks have flat bottoms and are aluminum.
smokingcrater
i've owned various jets for quite a few years. currently have a sugar sand tango 4+2 plus a couple jetskis...
shallow water. yes jets are not good at STARTING in shallow water, but as long as you are on plane, you shouldn't suck anything in, even in a couple inches. (i've run my tango MANY years in inches of water) I've even bounced across a couple sandbars that were just barely submerged.
like the post above me said, this is NOT a rapids runner... entirely different type of boat that also just happens to be powered by a jet.
TimeBomb
just sold my gp1300r so i'm getting there.
Soup Dog
I have a speed demon!!
A 12ft LOWE row boat!!! with a 1958 10hp Johnson!!!
I know your laughing but that little boat goes 22mph on the GPS!!!!
Now that's with just me in it, on a flat lake,with a concrete block in the front....
I also have a 22ft PennYenn we use for fishing on lake Erie for Perch and Walleye
Hillbilly
If I were you, I would go look for an older PowerPlay 18XLT. Those boats are cool and are pretty fast. Do you like to go 70mph and chime walk? and spend alot less money?
