autowrench
A friend is eyeing a 2002 MM with 151 suspension. The question is, can he swap the complete 151 into his 04 Viper Mtn with out making mods? Thanks!Tom
You may have better luck posting this in the Mountain Sled forum.
Yes you should be able to, I think the only difference in the 2 would be the rails.
you will have to relocate the mounting points and add some drop brackets to get it to work properly. the mtn skids front arm is mounted about 9" back from the short track. in addition you would obviously need tunnel extensions as well as longer coolant lines and hose covers. pretty much a straightforward swap armed with the right information.
