STEERJOCK
So my cousin dropped his sled off the other day for me to work on...Said he had the smartest people ever work on it (YEA RIGHT!!!!!!!!!!) First things I did was hook all the carb and coolant lines up right, put the carb boots on properly and fixed the gas leaks.
Anyways its a earlier model exciter (prol 89 or maybe 90) when you first take off it seems boggy but then opens up, then when it gets somewhat warm the motor seizes tighter than tight, then let it sit 15 minutes and you can pull it over again but wont start that time.
My brothers 99srx 600 before it went would seize up, then you would pull the plugs and put back in and that one would start again.
Are these just cooling problems or?
Thanks for the help!
