97 600 twin clutch rollers ?
Mitchell49601
Michigan
Just wanting to know which primary clutch rollers to buy to replace old wore out ones with on my 97 XTC 600,(Just the stock ones or something different ?) I would like something that lasts longer if possable, I'm running 8ab weights, Heaviest rivots in mid and tip and stock(Pink)spring, 50/44 microbelmont helix,green spring @ 70 rap, 89L belt, This is turks setup modified cause my weight is only 160 lbs, .06 head gasket, It still tries to over rev after mid even with 24/39 gears, 9T drivers I believe, If I try 60 rap then it gets sluggish on low and mid but will still over rev on top, I thought there was another little heavier weight he recommended for this aplication, Does anyone know which ones ? Or other ideas ?
I'll help others.
I'll keep track on here and help put this info where it needs to be with help, On the 600 twin I swear I can help I have to lead a rx 1 and a nytro this will succeed I've done it, Just can't be not knowing. 2 strokes can be Dialed. I can look and help.
