mikeast
Just changed secondary clutch , i noticed in the manual there are listing three shims mine doesent have that just the collor and bolt and washer question should it have these shims? and can i use any type of washer to replace these shims? ? also do you have to greese shaft lightly? do these collors wear out or how can i check ? seams like alot of play on the sleeve back and forth splines look good probaly because of lack of the 3 shimes im guessing? im ordering Aaen clutch manual but in the mean time appreciate any help
