Allvipedup
No no no!!! I just had a buddy run into the same problem....Check your clutches!!! That definately sounds like a shifting issue...are they clean? Make sure everything can move smoothly, be sure to remove all debris and build up....usually this stuff make the clutches sticky and they won't shift properly. You've checked everything else. The sled may be new, but where do you store it? How many miles are on it...etc take a look you may be surprised.
