Exciter Build Advice
bluewho
Caledon ontario
I have a nice clean chassis to work with need advice on rolling the chaincase.I am going to run a 136" 2"yamaha track with 8" drivers.
Would the 90 exciter chaincase be strong enuff or should i go to another style like a srx case and run the hyd brakes?Is there a longer chaincase than 7" centre on the bearings.
I will be useing a red head 700 with pipes,40" wide front end with good tss shocks,usi skis,and a origanal yamy mono snocross suspenshion.Will be leaveing the front cooler out and install running board style and maybie the exciter style lifted above the tunnel.
Doo Chaincase
Some of the doo chaincases are a bigger center to center distance from reading other articles, but i dont know which ones.
