TY Vmax Vintage Build Stage 3
MrSled
Site Admin/CEO
Staff member
Weston WI
Website
www.totallyamaha.com
Working on fitting the 136 Mono Skid into the Vmax Chassis. Had to cut down the front arm some and the brackets. Working out pretty good so far.
More of Stage 3
Finishing the custom mono install brackets. Adding tunnel extension and dry fitting the suspension. After everything looked good, we added the track in and dry fit track and suspension. All looked good so I drilled the adjuster on the tunnel side.
More pics
final for this stage!!
Thanks Chris, When you get the steering column and bars call me. What I would like to do is have you build us a Riser that would be able to take the Gauge Plate or even a Gauge Closer and then I would use the newer style hook bars instead of that one piece crazy looking thing...LOL
MrSled,
Was wondering if you made that tunnel extension yourself? If so it came out great!...I have to make one for my 95 vmax and hope it comes out half as good as that...I looked into buying a used one but I think it will be hard to find because the vmax has a 17.5in wide tunnel(OD).....Also did you relocate the rear heat exchanger or just do away with it...Thanks for your time...Sled looks fantastic!!
I relocated and made my own mount for the heat exchanger and I actually forced a Attack extension on the machine and pull the tunnel out to fit it.
