Working on fitting the 136 Mono Skid into the Vmax Chassis. Had to cut down the front arm some and the brackets. Working out pretty good so far.
Wow, that looks like about 1/2 inch per side.
1/4" lol, its all good
More of Stage 3
Finishing the custom mono install brackets. Adding tunnel extension and dry fitting the suspension. After everything looked good, we added the track in and dry fit track and suspension. All looked good so I drilled the adjuster on the tunnel side.
looking good.
Thanks, Its a lot more work then I thought it would be.
Truckkid42
man, ur gona have to tell us how it rides. i had a 96 i loved. looks good so far.
If I can get it all tuned in for the snow, I will have it on the rides and maybe let some users give it a rip
Looking good Tom.
Thanks Chris, When you get the steering column and bars call me. What I would like to do is have you build us a Riser that would be able to take the Gauge Plate or even a Gauge Closer and then I would use the newer style hook bars instead of that one piece crazy looking thing...LOL
Wow, that is going to be cool!!!!!!!!
Mike
Mike
MrSled,
Was wondering if you made that tunnel extension yourself? If so it came out great!...I have to make one for my 95 vmax and hope it comes out half as good as that...I looked into buying a used one but I think it will be hard to find because the vmax has a 17.5in wide tunnel(OD).....Also did you relocate the rear heat exchanger or just do away with it...Thanks for your time...Sled looks fantastic!!
I relocated and made my own mount for the heat exchanger and I actually forced a Attack extension on the machine and pull the tunnel out to fit it.
