RX-1ND
 - Dec 7, 2004
I have a 03 viper mt and I just purchased a set of SLP pipes. What is a good clutch combonation for 1,000 to 5,000 and also 6,000 to 10,000. The reason I ask for the two elevations is I live in North Dakota and also ride in the mountains. I would like to use yamaha clutching, but would like any advice that anyone has. It would be great to have a baseline on a clutching setup for going from 120hp to 140hp.
			Mtnviper
SLP's clutching chart for Mountain Viper's is very close, you may have to go up or down a gram or so, for your specific area. Clutch it to run 8700-8900 range. Power usually starts to fall off around 9000.
SLP does have their tuning specs on line at www.startinglineproducts.com, which is kinda cool!
terry
 - Nov 24, 2003
I too have a modded 03 mtn viper with slps...I have it clutched so I merely change out the primary spring from y/w/y---gr/wh/gr for the upper elev. I run a Bender red/ yellow sec spring with a 5147 helix, and with a 156' track can hold 52+ mph ind the hils
RX-1ND
 - Dec 7, 2004
Thanks guys, that is exactly what I was looking for. I order the pipes from my local dealer and the instructions probably come with them. I just didn't want to wait until they were here and then I would have been scrambling trying to find out information.
Thanks,
Chris
			Thanks,
Chris
terry
 - Nov 24, 2003
the key to this setup is the sec. spring..to hold the shift properly  been there done that
RX-1ND
 - Dec 7, 2004
I have installed the pipes and this thing rips. Now I would like to see if anyone would like to give there clutch setup for 8,000 - 10,000. The setup recomendation from slp worked alright for the 1,500 elevation I'm at now but when I head to the higher elevation I would like to have her right on the money. Anything you guys have for setups will be greatly appreciated.
			terry
 - Nov 24, 2003
You are going to have to go less weight and or more spring in the primary. what spring are you using???
RX-1ND
 - Dec 7, 2004
Currenlty I'm running what slp recommened for 0-3,000ft.
8dn10 - 13.3 steel inner hole, 13.9 outer hole
Primary - Grn-Wht-Grn(stock)
45 degree helix(stock)
secondary spring - Green(stock)
I will be heading to an elevation of 8,000 to 10,000. Slp does give a recommendation for that elevation but would like to get your guys input on any setups that will work well.
Thanks Guys
Thanks Guys
