I have decided to build a 98 sx 700 red head ice drag sled. I had a good chassis with just over 5k with no motor. I found a wreak 2000 sxr 700 with a good motor had pipes. I have a set of hauck pipes on my trail sled seeing that the pipes are trashed on the wreak. I also have a HC drag & fly weights. Will post sum pics shortly. Any one care to offer any setup input would be great.
My yamaha Yard
Here is my yami yard Black one on left is wifes 99 V-max 700 The 98 SRX on right by my boy is my buddy's that sled all most killed him in FEB now have to fix it back up. The donor and the red SX then there is a SRX chassis way over need hood of it for my buddy's wreaked SRX. Then the two on trailer SXR 700 00 is my trail sled Red sx 700 97 is my cousins. As you can see we love our Yamis
YAMI
YAMI
tell me you dont just let them sit outside ?? you pulled them out for pictures rite ??
No there summer home is out side I do not have room enough to put them in wish I did. I try to keep them covered up.
driftbuster
Try finding an old box from a wrecked truck. Unbolt it from the frame and set in on blocks. Makes a great storage facility, and it looks like you have the room for it.
Got started on the project sled on sunday. Got motor sent in got rear bent motor mount over oil pump to fix. Changed out wiring harness because the other one was taken out. Will post sum pic soon.
Pics and Updates
I painted a low windy. I have had to beat and pound on the rear motor mount. I need to find some skis and I need a damn o meter cable. Hope to have is going in a week or so.
sxr-x
I will give you a motor mount if you want. just pay for shipping.
Its alive! Just had sum brews and finished putting motor in.
What american pickers have to do wit any thing??Turk said:Series 2 of American pickers
But any way now I need to find sum 8ca weights to set my clutch up. Have sum odd and ends to finish up. Still need to find a damn o meter cable. And Yellow or red ski loops.
Hope to get out and do sum grass/slush drag'en this weekend. Will have to see how close I have the clutches. Hope to have a buddy show up that has a radar gun.
Well time has come to play. I got my hauck pipes on. Got to jet it up some. I have a track i shaved all the lugs off and am going to run 96 woodys gold diggers 1'' in for now then mix with some chisels. I have a 8ca set up with 15.6mm rollors hauck org and a 51/43 helix green spring. Running 22/40 gearing. Should i strap it down? I have hot rods on it. Wanna do some heads up drags and 1000ft radar runs. The motor is all stock exc for pipes and reed spacers. Going to run some 93 (if I can find some good gas) Any tips any one care to share would be great.
Going to post some new pics and get some action pics as well.
Dug sled out last night started cleaning up. Got my track this week. I wanna get some quick pixx for it. I found some close outs on aaen hope they are push through no t-nuts. Think I am going to wrap my pipes this yr. I will strap it down this yr to. Wanna have Don port it. I need to take all the unneeded weight off it to get it down. Any pointers you guy have to take weight off sled hit me up please. What do i need to do to run no air box? Or would I be best to run a gutted air box?
