Corey9965
I am wondering what Hauck or Dalton helix is comparable to the Advant-Edge 48/42? I have a 54/44 Hauck and a 50/42 unknown brand and am gonna try 89a-10's for field and lake racing on my trail sled this winter. So if you guys can give me a close helix to start with it would be much appreciated. Also what primary spring do you guys think. I have a WWW already. I am putting this in a ported SRX 700. Thanx.
Corey
Corey
YAMMIEGOD3:16
COREY, OTHERS WILL ANSWER DEFFERENT HERE, BUT ONLY THING I CAN SUGGEST TO YA IS YOU HAVE TO ACTUALLY FIELD TEST WHAT YOUR LOOKING FOR. SOME HERE SAY THOSE ADVANT CAMS ARE RIGHT ON, I NEVER USED ONE SO I CAN,T TELL YA. 89A-10 WEIGHTS ARE GREAT FOR WHAT YOUR LOOKING FOR, SO IS THE W-W-W, AGAIN YOUR GONNA HAVE TO TEST. 3;16 (yammie tony)
corey, I can give you a complete setup information to try,rivet placement in the 89a10's,primary spring, helix and rear spring set up to install.
youll still need to field test as tony says,every sledtheresalittledifferance, riderweight,snow type, track type,etc. but I can get ya real,real close on rpm.
Corey9965
Sounds great, Don. The motor ships out tomorrow so you should have it by the weekend barring any unforseen circumstances. That's one of the reasons i wanted to make the trip out by you to put the motor back together. I wanted to pick your brain on clutching.
