Where would I find pre-cut grip tape to fit the running boards of a 00 SRX?
T.S.U.Filmz
don't bother it will just peal up from the cold and water. I do have a set of fett bros running board grips if interested
KneeDown said:Where would I find pre-cut grip tape to fit the running boards of a 00 SRX?
I've never used the pre-cut rubber ones you find in the aftermarket catalogs, but I've made a few sets for myself from 3M safety tape. It's the sandpaper like stuff used on ladders and steps. I found some in 5" widths and cut to fit the board. I used a gasket hole punch where the stuff covered a rivet (cut to fit, lay over the area and tap the high spots above the rivet to locate the hole).
I cleaned/prep'd the area with alcohol and both applications have stayed put.
Don't know if the adheasive is any better than the pre-cuts ones, but lifting due to cold/moisture hasn't been an issue.
Yeah thats what Im using now is the 3M grip tape. Fantastic idea on the hole punch, maybe ill try it again as that was the problem i was having. Ill have to look for some 5" width stuff too as the tape i got was only 4" i believe.
