bluemonster1 said:off course you use compressed air.............why would you even ask that question.Haven't you ever cleaned carbs before?????![]()
norwegian said:As a matter of fact, I haven't that's why I'm asking.
A couple of bucks said:A cutting torch Tip Cleaner can also help. Obviously the very small ones.
YooperMike said:This is just a thought, never tried it, but would the little cans of compressed air you can buy for cleaning out computer keyboards and other electrical stuff work? Seems like it would....just to get the gas and other solvents out anyways. Cheaper than a new air compressor.
A couple of bucks said:I accept ZERO blame should you do #1 of the following.
1. Grab the wifes ULTRASONIC jewlrey cleaner.
2. Get a small can out of the recycling bin. Mabey a small mushroom or tomato paste can.
3. Get the fluck out to the garage before the ball and chain catches you and puts you on the.....NO POA LIST.
4. Grap your favorite solvant.....my all time favorite is MEK (methel ethel ketone), and clean till your hearts content.
5. Obviously no rubber parts in this ultrasonic witches brew. Especially with MEK.
6. Hide that MFing ultrasonic cleaner in the man cave so she will NEVER find it.
7. Concockt story in mind about the flipping cleaner so when she asks you where it is...you don't just stand there and stammer around. Something like..."the sink leaked and I had throw it away"
MAY THE FORCE BE WITH YOU
Plus you get the added advantage of seeing what Carb Cleaner tastes like. For added measure I usually get some Carb Cleaner in my eyes. Now that's getting your money's worth.mrviper700 said:You can even just simply blow thru the jets with your mouth if they are clean. If they are clean you can see light thru the jet.
reassemble and run it!![]()
Ding said:Plus you get the added advantage of seeing what Carb Cleaner tastes like. For added measure I usually get some Carb Cleaner in my eyes. Now that's getting your money's worth.
Just kidding guys. . .
