will 68L chain work?
mopar1rules
manitowoc, wisconsin
does anyone know off hand, if a 68L chain will work for 22/40 gearing? i know the chart says you need a 70L chain, but it also says that a 70L chain is needed for 23/38 gearing, when i know of guys that still run the 68L chain w/that setup, as the 68L chain fits/works. thanks guys.
JOSH, I RAN 21/40 FOR 660 ICE DRAGS USEING THE 70 LINK CHAIN. I DON,T THINK THE 68 WOULD GO ON. ALL YOU CAN DO IS TRY IT. 3:16 (yammie tony)
valin said:
Nope. You are 1 tooth too high for a 68L. You can only run a max of 61 teeth on a 68L.
Ok, thanks guys.
That's good to know valin....61 teeth max for 68L chain. What is the max for a 70L chain?
THE KEY TO RUNNING THE RIGHT CHAIN REALLY AIN,T '' SNUG ''. THE KEY IS HAVEING ATLEAST AMOUNT OF BEND AS POSSIBLE. 3:16 (yammie tony)
