need help front heat exchanger
sxr dude
i have a 2000 sxr 700 rip a stud half way out of the track and killed front heat exchanger does anyone have any info on going about changing it or can i weld it stud put a grove down the hole thing thanks any info would be great :yam:
yes you can weld it because it is 6061 t6 aluminum. Make sure you know what you are doing when you weld it. It saves to $100 if you are able to weld it shut otherwise there are always new heat exchangers on ebay for $100. HOpe this helps
