my srx on grass?
yammieguy
huntsville ontario
going to run some grass with my 2001 srx up near me and have some questions after searching through the forums.
Gearing- I am thinking 19\41 with a trail studded track, sound close?
Jetting- It seems 132.5 and 133.8 is a good starting point with a 50 pilot. Would you raise the needle 1 position? Guys running in this area of jetting are you using straight pump fuel or cutting it?
Air Screw- 2 turns?
Air jet- what and where exactly is it in the carb?
Where can I get the best price on these parts?
Timing key- is it worthwhile to order one on a stocker?
Hopefully I can get some response here and keep this a rolling forum, I would like to see my sled run 5.70-5.85 with trail track and studs so I can try a couple amateur cosdra races!! Thanks all!!
There is a run down in Fenwick coming up, not too far from huntsville and a good place to test.
