srxr700 said:
If your looking to go fast go with the srx, its already got all the goodies for triple pipes, larger rear heat xchanger, thinner head gasket, larger carbs....and its more of a classic in my opinion. I tear my brothers viper up.....
a srx and viper use the same 33 mm carb size
a viper uses a headgasket with its monohead design, a srx has o-rings not headgaskets for its individual heads.
I would say if you want maximum fuel mileage with the stock power youd have to buy a srx, because they will get 12-14mpg all day long if its clutched/geared correctly. The srx weak point is its short travel suspension that will become very evident as soon as the trails get beat up. So it would be cheaper to long travel a srx then mod a viper up,but theres some points I will make about a mod viper.
PROS:1.) modded viper with a simple installation of triple pipes has more hp(On average about 10, for a 150hp) then a srx does(140hp).
2.) viper is lighter then the srx
3.)long travel suspension works decently if set up to your riders weight and style
CONS:- 1.) fuel mileage will be at best 9-10mpg if your clutching/gearing is perfect, the triple pipes require larger pilot jets and richer midrange to run the pipes and cope with the extra ign. timing of the viper cdi box
2.) no where near as stealthy, a piped viper will be known even the slp pipes have a tone to them, and with the new exh. laws in effect is something to think about.
3.) if your not a tuner and someone who just wants to ride and not check plugs,etc. a piped viper should be avoided.
