No Spark
BURMAD69
New Lisbon Wisconsin
I'm working on an old Exciter 570LC it has no spark, tested kill switch.tested ignition switch, checked grounds, replaced CDI box, thinking possibly stator what do you guys think??
if your sled is equipped with a version of tors, i have seen the carb switch go bad and kill the spark. there is an ohm test for this as well as the stator output. simple as specified omhs resistance at specific wires. what year are you working with?
