hey all,
am wanting to put a 120 inch rev xp track with 1.25 lugs that has a 2.86 pitch on my 02 sxviper...
can you buy anti-rachet drivers to make this track fit?
how many tooth?
thanks alot guys
how many tooth?
thanks alot guys
Yes, 7 tooth 2.86 is close to the same size as 8 tooth 2.52.
Get the 1-1/16" shaft size.
Some of the advertisers on here sell them.
dirtjumper895
Or try avid-products.com... Im pretty sure they have cnc'd drivers.. Pretty bling, but spendy.
			thanks alot guys, it has 8 tooth driver stock right?
so the 7 tooth 2.86 drivers will be enough to clear the 1.25 track?
will only need 2 of them because they run in the clips...correct?
so just to double check here are the specs i need...
1 1/16 hex shaft
7 tooth
whos drivers are the best quality for the buck?
1 1/16 hex shaft
7 tooth
MicroBelmont make good quality aftermarket drivers. You can order them through Royal Distributing.
			thanks guys, the wal bros seem to be the best priced, am going to go with them...
cant wait to see how the sled hooks up with the thin 1.25 track and mpi transfer kit!
if you havent already placed an order, cbperformance, a site sponsor/vender can get you those drivers.
