thanks alot guys, it has 8 tooth driver stock right?
so the 7 tooth 2.86 drivers will be enough to clear the 1.25 track?
will only need 2 of them because they run in the clips...correct?
so just to double check here are the specs i need...
1 1/16 hex shaft
7 tooth
whos drivers are the best quality for the buck?
