filo_bedo
I know clutching comes up constantly on the forum but this year I am finally going to change the clutch as I hear it gives a fair amount of performance for the buck and would like to get some opinions on whats best.
I own a 2001 SRX and probably trail/lake ride 50/50 of the time on the sled. The sled is basically stock and since I will be tearing down to clean and prep everything for the upcoming season, I figured I would make some changes now.
This is listed on this site as a good trail/lake set up, would most agree or would anyone change anything? Please be specific on what you would change as I have only owned this sled 2 yrs but think its one of the greatest things I have ever owned...lol. Therefore I know every little about clutching.
48/42 Helix, 89a-10 weights w/2.4g rivets in inner hole, .8g rivet in the outer and stock springs.
I also plan on upping the gearing by one tooth to gain a little more top end speed.
What do you guys think? Do you see any problem with doing both?
Here's a good setup for trail/lake by YAMMIEGOD3:16
8BU-10 WEIGHTS.
4.5 RIVET IN TIP
4.5 RIVET INNER
50-40 HELIX @ 80
GREEN SPRING. NOTE :. MIGHT UNDER REV, SWITCH TO STOCK RED SPRING.
NOTE: I USE MAXXIMUM PERFORMANCE SRX SPRINGS. HARD TO FIND NOW. POSSIBLY W-W-W WOULD BE FINE. MIGHT NEED TO FINE TUNE ENGAGEMENT TO ATLEAST 4500 WITH A SHIM. REAL NICE ALL AROUND CLUTCH SETUP THAT REALLY PULLS HARD MID RANGE. WHISH I HAD LONG STRETCH TO REALLY FLY. 3:16 (yammie tony)
8BU-10 WEIGHTS.
4.5 RIVET IN TIP
4.5 RIVET INNER
50-40 HELIX @ 80
Huh?
So you are telling him that if it under revs he should change from a green spring in the secondary to a red one???? Interesting advice.
Madmatt
Madmatt
no I just posted what Tony put down for a setup
YAMMIEGOD3:16
MATT, I RAN 110 IN 1000 F.T. WITH THAT EXACT SET-UP WITH MY 2002 SRX ON ICE. THIS WAS DONE ON STALKER RADER GUN AND A GPS ON MY SLED. DRIVER WAS 145 POUNDS. ITS NOT A QUESTION OF WHAT RPM WILL DO, ITS THE COMPLETE SET-UP I USED. 3:16 (yammie tony)
Not questioning the set up
Tony I'm not questioning the set up.....I'm questioning how under-rev could be cured by going to a WEAKER secondary spring...that's all. I know a little about those weights......I believe you bought them from me, didn't you?
Madmatt
Madmatt
YAMMIEGOD3:16
SHURE ARE YOUR WEIGHTS. I OWE YA BIG THANK YOU FOR SELLING ME THOSE. BELIEVE IT OR NOT I HAD GREEN SPRING WITH THIS SET-UP AND THE RPM WAS SLIGHTLY OFF. SHURE ALOT COULD BE CAUSEING THIS. WEIGHTS, HELIX, etc. I INSTALLED STOCK RED SPRING WITH SAME TWIST, RPM WAS SPOT ON. 3:16 (yammie tony)
filo_bedo said:I know clutching comes up constantly on the forum but this year I am finally going to change the clutch as I hear it gives a fair amount of performance for the buck and would like to get some opinions on whats best.
try and try and try this is the secret
8BU 00 Weights 3.6 GRM rivets in the tips, none in center.
Straight 45 helix 70 degree twist
Stock Primary Spring
Green string
YWY stock
Only tested in yard grass.... Way faster than stock...
But im looking too radar 1000 and trailer..
Green string
YWY stock
YAMMIEGOD3:16
YOU WILL NEVER BEAT MY 8BU-10 SET-UP IN 1000 F.T.WITH 8BU-00. IN A DRAG RACE YES, TOP SPEED, NO WAY. 3:16 (yammie tony)
YAMMIEGOD3:16 said:YOU WILL NEVER BEAT MY 8BU-10 SET-UP IN 1000 F.T.WITH 8BU-00. IN A DRAG RACE YES, TOP SPEED, NO WAY. 3:16 (yammie tony)
don't u think 89a-10 will beat those 8bu-10 on top speed
YAMMIEGOD3:16
NOPE!!! WELL REALLY SHOULD NOT SAY THAT. ALL COMES DOWN TO ONES SET-UP. ALTHOUGH I DID A 89A-10 SET-UP IN A 01 SRX AFEW YEARS BACK, 8BU-10 PULLED WAY HARDER. 3:16 (yammie tony)
mattyg1405
any advice on doing this for the first time? it would be greatly appreciated...
what kinda 50-40 helix? Is this setup going to way under rev with a 250Lb guy on the sled?needaSRX said:Here's a good setup for trail/lake by YAMMIEGOD3:16
8BU-10 WEIGHTS.
4.5 RIVET IN TIP
4.5 RIVET INNER
50-40 HELIX @ 80
filo_bedo
Thanks for the info guys. Here is a stupid question, what is the difference between 89a-10 and 8bu-10 weights?
YAMMIEGOD3:16
50-40 I USE IN THAT SET-UP IS A MICRO- BELMONT.
8BU-10 - 45.41 GRAMS
89A-10 - 47.5 GRAMS
8DN-20 - 42. 0 GRAMS.
8BU-10, s HAVE SIMILAR PROFILE TO 8DN-20 , BUT HAVE MORE MASS IN CENTER OF THEM. 89A-10,s ARE GOOD WEIGHTS. KEEP IN MIND, ALWAYS HAVE TO TEST , NO MATTER WHAT CLUTCH SET-UP YOU GO WITH. 3:16 (yammie tony)
89A-10 - 47.5 GRAMS
same set up world record srx ran arond 115 in 1000 on ???? Of course set up for racing not trail like mine..
Guess we will see when the ice comes, i mean i have not even tested it yet. So you may be 100% correct. I weigh 220 though.
What is your opinion on this set up then Yammie tony
bojisrx said:Guess we will see when the ice comes, i mean i have not even tested it yet. So you may be 100% correct. I weigh 220 though.
there is no trick its only alots of time of try and error
If you can get the set-up of Sandy Reids SRX please let me know cause I can't get anything out of them on its set-up. I would sure like to get my SRX to do 115mph in 1000feet I have a guy that is going to be riding it for me this year that weighs about 140Lbsbojisrx said:same set up world record srx ran arond 115 in 1000 on ???? Of course set up for racing not trail like mine..
