As you can see from my join date I have been looking for a clean, low mileage, stock SRX. I never ended up finding anything reasonably priced last year so I picked up the search again about a month ago. I found this one on Craigslist. REALLY clean, totally stock and VERY well cared for. As you can see from the PV's they needed very little cleaning but that was the first thing I did. I will clean the carbs tomorrow after I read in the tech section how to get them off.
Power valve before cleaning
Power valve after cleaning
I would say you stole that for 2000, if those powervalves were already that clean, someone took care of it....enjoy that sled!
wow thats clean, nice work, and now you can spend money upgrading instead of fixing things!!
u need any help or questions just call me and i will go over it in detail on how to help. pete 616-822-0606. srxs foreverer.
super1c
Super Moderator
Wow nice find, very clean. CCC
Congrats very clean looking sled Yes SRX's forever
tomorrow I want to take the carbs off and clean those- - do I take the airbox off first then the whole carb rack? I looked in the tech section and didnt see anything except on the actual cleaning
super1c
Super Moderator
Yes take the airbox off first. Just makes the whole job a lot easier. CCC
better spray some wd-40 or penetrating oil on the screw that hold the boots on the carbs as they tend to strip if you don't have the right screwdriver LOL
very nice sled congrads power valves look to be in good condition did you remove them from the cable to look for sighs of pull thru ?
Congrats on one clean SRX! You will love it!
sgauthier
nice clean looking sled. congrats
No- I pulled them out and the cable was attached to the valve so I figured all was good- what should I look for?YA*AM*A*HEAD said:very nice sled congrads power valves look to be in good condition did you remove them from the cable to look for sighs of pull thru ?
abumpa
Sled looks great...congrats!
sgauthier
just remove the other 2 allen head bolts on the top each of your power valves where your fingers are in your picture above, pull it apart and check the cable end and the slot at the top of the valve. just make sure the cables are in good shape and that the end of the cables haven't pulled thru or made the end of the valve so thin it might be about to pull thru. when you open it you will know what we are referring too.
everytime i ressemble that area i always add a little grease in the slot to help lubricate the end of the cable, but that is just me, not sure if it helps but it doesn't hurt anything
good looking ride bro, awesome deal
Robs96max4
thats awesome.. that sled would be easy $4000+ here in Ontario
mulderdad
Wow!
Nice deal man!
Nice deal man!
