I read the write up multiple times and it just doesnt seem to be working for me,
1. I removed the servo cover
2. started the engine and then using the screw on the top of the carb rack I turned it until the idle went down below 900 rpm. It seemed that at that time my servo was going back and forth so I lowered the rpm further until it stayed still.
3. I loosened the 2 screws on the front most PV housing and put a 2.5mm allen wrench in there to make the correct spacing. It just seemed like the servo would keep moving even though the engine was running smoothly but at a low idle. It just didnt seem like I could tighten the cable adjusters to get the housing to tighten- should I be screwing them "INTO" the servo housing to tighten the PV housing.
I guess my question is do I adjust the PV with the engine running or once I lower the rpm's and the servo goes to that point do i shut it down?
Help before I go to the stealership
