I am on Bender's site looking at power packages and they are mentioning "adjustable torque arms" and "transfer rods"?
what are they? suspension components?
transfer rods aid in transferring weight back by collapsing the suspension when you pin it.Adjustable transfer rods are fully adjustable to limit the amount you want to transfer back.In other words your suspension folds down more to aid in better traction.To much transfer and you will have ski's up and no steering..but it looks cool!!!!!
i have bender transfer rods for sale if you needed some new ones
torelloracing
bluemonster1 said:transfer rods aid in transferring weight back by collapsing the suspension when you pin it.Adjustable transfer rods are fully adjustable to limit the amount you want to transfer back.In other words your suspension folds down more to aid in better traction.To much transfer and you will have ski's up and no steering..but it looks cool!!!!!![]()
i also have bender rods on mine and they are all the way to where i hang the skis for ever but am racing in the grass on sunday would it make sense to adjust theme all the way in other direction ?? or would that not be good i wanna launch as best i can ?
adjust them 50/50 for starters.Also check your limiter straps.The tighter they are the more ski pressure.Let out to much will allow less ski pressure.The 2 work with each other.
torelloracing
thanks for the help !!
jamsf1984
how much for them if u still have themj2hizzo said:i have bender transfer rods for sale if you needed some new ones
