Ride.Race.Live
Do any of you's do a leak down test on your engines?
For example... I own a banshee and peeps say i should do a leak down test after a rebuild and make sure it can hold 6psi over 6 minutes to ensure there are no leaks...
was wondering if any ones does that on their triple and if its possible and if so how much psi do you put in it..
SCRATCH THIS POST.... finally found the sticky with the info for this
