bluemonster1 LIFE MEMBER ONLY ONCE!!! Joined Dec 30, 2005 Messages 12,690 Age 69 Location Howden ,Manitoba,Canada Oct 15, 2010 #1 what is the #1 cylinder..is it the clutch side and #3 would be mag side..can't remember.Reason I ask it says in manual to align cylinder gasket with the notch between #1 and #2..
valin Active member Joined Apr 7, 2004 Messages 2,075 Age 47 Location Val Caron, Ontario Oct 15, 2010 #2 PTO is number 1.
bluemonster1 LIFE MEMBER ONLY ONCE!!! Joined Dec 30, 2005 Messages 12,690 Age 69 Location Howden ,Manitoba,Canada Oct 15, 2010 #3 what is the correct method of installing circlips.Does open ends end up in the recess of the opening.
valin Active member Joined Apr 7, 2004 Messages 2,075 Age 47 Location Val Caron, Ontario Oct 15, 2010 #4 The open ends of the circlips should be as far away as the recessed opening in the piston.
bluemonster1 LIFE MEMBER ONLY ONCE!!! Joined Dec 30, 2005 Messages 12,690 Age 69 Location Howden ,Manitoba,Canada Oct 15, 2010 #5 yes we figured that .Thanks.....
