700EFI Engine Is Going In My Exciter II
ExciterII569
Whitehorse, Yukon, Canada
Just purchaced a wildcat mountain cat 700 efi for a good price and the engine is already being ripped out so I can install it in my exciter, should be pretty damn sweet!!!!
Engine is same width, will be mounting it jugs straight up/down, making custom engine mounts as we go.. purchasing an aftermarket out of tank fuel pump so I can use my stock tank/seat, going to find a manifold/pipe setup that fits into the exciter chassis so its all stock looks outside, and BEAST ENGINE underneith. :D Looked around online and have gathered enough info to safely say the 700 efi engine has 125-135 hp stock, much better then the what like 82hp the 570(stock) has, my 570 prob has 90-100 hp(with mods).
Here is my current setup:
1992 Yamaha Exciter II 570cc
Flat black paint job w/guages re-located, no headlamp
Aftermarket handle bars/5" riser/pivot adapter
Custom 136" track extension
Custom tunnel extension/rear cooler re-locate
Custom skid drop plates
136x15x1.5" track w/8 tooth drivers
Wide plastic powder skis
DG Performance exhaust
Modified airbox
Oil injection removed, runs pre-mix
Tuned/adjusted clutches
Carburators regularly jetted for mods/altitude/temperature
Seat needs bit of work
Will be installing 7 tooth drivers and a 136x15x2" to support my 700cc's ;)
Will post pictures regularly or make a link.
Feel free to fill me in with any info or ask questions if you'd like
You will be fine if you have extra crankshafts, pistons, cylinders and clutches.
