yamaha_nisse
Hi,
I have a 500cc SXR twin. And i want to upgrade it to a 600cc..
Do the 600cc have the same stroke?
So its just to take cyl/head/pistons from the 600 and bolt on to my 500?
Also, if someone has a pair of 600 cyl + head. I'm interested.
Clutching is a later question ;D
Thanks Rasmus
Thanks Rasmus
you will need, carbs, wire harness, head, cylinders, pistons, clutching and gears.
for all the work, updating to a tripple would be a better move, more parts but they last longer and are better on fuel
SamuelJackson
Buy a triple...period
Everyone says the triple is better on gas how is this?
yamaha_nisse said:Hi,
Thanks Rasmus
Hey Rasmus is it hard to be Nisseman?.............................yeah its hard to be a nisseman............
LOL. Howcome you heard of that? That' a qoute from a norwegian advent tv show!
man never thought t hat would reach all the way to canada?
The julekalender:
http://www.youtube.com/watch?v=HpuM9s2r_tM&p=EA683B2EB3D5BF8F&playnext=1&index=3
Note the norglish the nisses speak. LOL
man never thought t hat would reach all the way to canada?The julekalender:
norwegian said:LOL. Howcome you heard of that? That' a qoute from a norwegian advent tv show!man never thought t hat would reach all the way to canada?
.......Lol , it didnt, i worked in Norway, i used to know the words to a bunch of the songs, still makes me laugh to think about 'The Yulekalander'.
Ah ok, explains it
yamaha_nisse
BETHEVIPER said:you will need, carbs, wire harness, head, cylinders, pistons, clutching and gears.
Carbs? They have the same specs?! Mikuni TM36x2. Re-jet maybe.
How come I need a new harness?!
Gears and clutching I would prob have in the garage aswell.
But I'm restoring a SXR 500 '01, that I'm gonna have as a spare sled or just sell it!
So I want to stick with the twin. I know the benfits of the tripple, but not for this project!
The motor just need overhaulin, so its just as cheap to upgrade it to a 600.
Cyl, head and piston is like 250$ and then I can sell the left over parts from mine for like 150-200$
The SXR600 twin is VERY rare in Sweden.
Should be able to just swap the top ends. Case/stroke are the same, cylinders will slide right on. If you say the carbs are the same then a rejet should cover that. As for the CDI, I don't believe that there is anything different. Timing program might me a little different, but probably not enough to make a difference. I wouldn't be surprised if it was the same part though.
