Speedwerx triple Clutching setup
Im experimenting with a set of thunder product's heavy hitters in my p85 right now. Ill comment back once i get it dialed. Have you had your guage checked for accuracy? I know alot of guages can read even a couple hundred rpm off. I am going to check my guage soon.
Loaded up the 8DN-10s with the 17.2mm 4.5g rivets in both holes. Grabs 9000rpm perfect on top. Thanks mrviper for the help!!
Setup
W-W-W Primary Spring
8DN-10 with 4.5g in both holes
Green secondary spring
45 degree helix
Wrapped at 70
Geared 21/40 (stock spec)
Speedwerx triple pipes (no cooling mods)
The motor is all stock with the factory rear heat exchanger. I have yet to see a hot temp light on this sled. Only thing not stock is the pipes and jetting for it, the W-W-W primary spring, and the rivets in the weights. Rest of the sled is completely stock.
I have yet to ride this sled very much to see if I have any DCS issues with it. Dad rode it tonight for about 15-20 miles and said there was no issues. But I'm not complaining, just means I need to do some more riding to check it out myself.
good, did it cool off the clutchs with adding the weight? what twist is in the rear clutch?
Haven't rode it a whole lot. I did take some good hard WOT pulls, about 6-8 back to back with it after I did the clutch, and the clutches were hot but I could hold my hand on primary and secondary.
Twisted at 70 in the rear clutch.
