Does anybody know what it takes to put an 06 APEX suspension under a 02 SRX?
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
Here is a step by step installation on a viper with the same chassis as the SRX. The apex mounting brackets are not required if you just use the stock front mounting brackets on your SRX with slight modification. Hopefully this helps
http://www.totallyamaha.com/snowmobiles/aaTECH/Mono_Install/Project Monoshock.htm
mattyg1405
thats a swap that has crossed my mind soooo many times i would love to hear some feedback from people with the mono... it seems like it would be a great skid and i would really start to look for a monoshock skid if i knew how it would react in the srx im afraid of losing performance in the straightline/turning department... anyone have any suggestions?
Last winter...2002 SRX...fresh motor(stock)...MONO installed...reverse installed...185-187km/h on the dream-o-meter on the lake and it sucks up the bumps GREAT!!! I'm happy! A little more tuning this winter and who knows!?!
SRXSRULE2
I did my viper last winter, there is a write up under working log. Night and Day difference.
Northern what did you do for front shocks when you upgraded to the APEX suspension?
My 2002 has the OHLINS front shocks, stock ski's with Woody's 8" carbides. I set the spring's up loose, then tightened the lock nuts, damper set at the middle position. I set up the MONO's spring as per instructions so it has approx. 2-3" of sag (measured at the bumper) with me on it. Sled rails and does not dart... hope that helps!
