MUSTANG1
Wondering what damage is done if any, if regular octane fuel is used in sled. When in Canada, not sure if I can always obtain premium fuel.
winterfunguy said:Don't run regular in your SRX! These sleds are fairly high compression and you run the risk of burning the engine down by causing detonation which is caused when the fuel pre-ignites due to poor octane ratings and or water in the fuel. Now take into account that many gas stations have higher and higher methanol content, now you are begging for trouble. By straying from premium you are almost guaranteeing disaster, because even premium is becoming marginal with the methanol...methanol absorbs water and causes the fuel quality to quickly diminish...causing detonation...causing piston seizure.
Turk said:If you can only run regular sell the srx & buy the redhead triple. You will detonate & take out an SRX engine either running regular &/or strate 9es plugs.
Turk said:The es,s burn too hot & i have seen a few of em go down running this plug on a cold day on a long hard pull.They run a lot hotter then the stock 10 ecs. Spend the dough & run the 9 ecs.
