383stroker
i seen some guys running some bigger carbs on srx's. i was wondering what they are doing with the throttle position sensor? beacause i have been thinking about putting larger carbs for the ashpalt drags.
thanks Dean
thanks Dean
madzx2
cutlet performance center or cpc sells a tps relocation bracket. it might work. i think it needs another cable to operate it?
mopar1rules
madzx2 said:cutlet performance center or cpc sells a tps relocation bracket. it might work. i think it needs another cable to operate it?
you mean "CUTLER performance center". they are nice people to deal with.
if your just doing drags it wont make any differance, simply just unbolt the sensor and plug it into harness and ziptie to harness, the timing is only changed at mid throttle cruising and the TPS has no effect at wide open throttle. I dyno'd a srx in all differnt configurations with the tps at rest, mid and wide open. no differance in end result hp output. You only need it for trail riding.
yamalars
Pretty expensive thow..madzx2 said:cutlet performance center or cpc sells a tps relocation bracket. it might work. i think it needs another cable to operate it?
http://www.cpcracing.com/site/256083/product/CP-001-8100
I'm gonna have the same problem and dont wont another cable to mess with!!
So Don, is the timing gonna be the same at 8500 rpm. wo. tps?
383stroker
that makes my life a hole lot easier thanks alot.
yamalars
Ok thanks! I gonna try trail ride it wo. the tps. then and semrviper700 said:
how it works?
383stroker
no,i only ashpalt drag this srx. i ride another one on the trails
yamalars
Oops! I meant my self there! Edit it now Sorry,my bad!383stroker said:no,i only ashpalt drag this srx. i ride another one on the trails
