bigger carbs
383stroker
ontario
i seen some guys running some bigger carbs on srx's. i was wondering what they are doing with the throttle position sensor? beacause i have been thinking about putting larger carbs for the ashpalt drags.
thanks Dean
cutlet performance center or cpc sells a tps relocation bracket. it might work. i think it needs another cable to operate it?
if your just doing drags it wont make any differance, simply just unbolt the sensor and plug it into harness and ziptie to harness, the timing is only changed at mid throttle cruising and the TPS has no effect at wide open throttle. I dyno'd a srx in all differnt configurations with the tps at rest, mid and wide open. no differance in end result hp output. You only need it for trail riding.
