panshovel1966
Just bought a 1994 vmax 600 st for my son(standard clutch,slp pipes,160 main jet and 50 idle jet). I have check the carbs they are clean everything seems to be adjusted righ apart from the air screw that is on the side of the ventury it was at 1/2 a turn and i set it at 1 turn, and i must tell you that the clutch is weak it engages at around 3000 rpm. thats it for setting now here comes the problem, the sled starts great no prob you take off and its got good acceleration you can take it to top end no problem and as long as you stay at high rpm it runs fine but as soon as you let of the throttle and then try to go again it starts to run bad wont go over 4000 rpm sometimes if you play with the throttle a bit then it will go again but mostly it stays there until you stop and let the rpms go back down to 1500 rpm. I have tried disconnecting the TORS system no difference. What could be the problem.
Please help!!!
Please help!!!
