Pto ???
04VIPERS
Mass
:o| Took PTO off to grease my bearings. Is there a order in which the PTO go's back on?? or can I just put it back on.
I apologize, but I am completely lost at that statement. Can you please better describe what you are considering a "PTO"? I would only assume you are referring to the primary and secondary clutches......
Just put the secondary clutches back on, any old way?? does it have to lined up or just stick it on an bolt it down?
Well the clutch that goes to the motor is the primary clutch. If you removed that then first torque the bolt to 85ft/lb then loosen and then retorque to 43ft/lb. If secondary put back on with washers as you took it off and torque to 46ft/lb. Good idea to check your offset also. Can do with a straight edge and a ruler. should be 15mm+/- 1mm. CCC
