BlueMachine said:For the record, I believe that the marks in the exhanger were from when my shock blew out and I was bottoming out horrifically.
The marks are from running a studded track without rear HX protectors.
BlueMachine
Agreed. I meant that the marks were from the studs making contact when I bottomed out.
BlueMachine said:Agreed. I meant that the marks were from the studs making contact when I bottomed out.
What I was trying to say was that a blown shock won't change the point at which the susp bottoms. You may get there a bit quicker with a blown gas charged shock but the susp doesn't bottom out further with a blown shock.
Now if the skid hasn't been out for service you may have other worn/broken parts that could change the point of bottoming (worn shock bushings for instance) but even with worn parts in the skid rear HX protectors more than likey would have prevented contact.
Anyhow, since you're pulling the skid to replace the track now's a good time to tighten up the skid. Do a search on BeTheViper's write up for skid service.
BlueMachine
Ah I see. I'll go look that up now
thanks man.
snomofo said:What I was trying to say was that a blown shock won't change the point at which the susp bottoms. You may get there a bit quicker with a blown gas charged shock but the susp doesn't bottom out further with a blown shock.
duster_791
That Video of the track coming off is insane!! What are the odds of it hitting the camera man, ouch ouch ouch! I would say HE needed a new track for sure lol
A couple of bucks
duster_791 said:That Video of the track coming off is insane!! What are the odds of it hitting the camera man, ouch ouch ouch! I would say HE needed a new track for sure lol
The camera man probably needs new ankles .
