yamisx600r
I was wondering if any one knew wheather it would be better to put clutch parts or a clutch kit in a 2000 yamaha sxr600. I want to have good accelaration with decent top end, like around 100.
3.6 gram inner & outer rivet....8500 rpm bang on for $10.
yamisx600r
Okay, is there any thing else i need to do? Like springs or any thing with the secondary?
where can u buy rivetsTurk said:3.6 gram inner & outer rivet....8500 rpm bang on for $10.
yamaha dealer, part number is 90261-06034-00
A couple of bucks
Would the rivets that you have posted in the tech section have a favorable affect on a Bender 9770. Was in the sled when I bought it. I believe it is a 49/37 ???? 4.5g in 1st hole and 3.1g in tip.
2 to 3 engagement shims are also recomended. Will these need to be purchased or is the 2 to 3 a low number than what is in there ?
