Ok so here's the deal the bracket on my carb rack that the throttle cable screws to is for all intense and purposes wore out as far as I can see.I noticed last year that the lock nut on the cable would not stay tight and with a bit of deducing I found that the hole for the cable was spread a bit so I squeezed it back together but it didn't stay.Now the cable is wobbling in the hole and I guess my only option is to change this bracket which is becoming harder than I would have anticipated as I can't find the bracket itself listed in any parts breakdown.So what are my options here fellows?I guess I could take the bracket off and have a machine shop cut the worn tab off and weld a new piece of metal back on,drill tap and cut it like the original for the cable.
Anyone got one of these brackets lying around?
