aaen black/orange primary spring
40/130kg--2.75kg rate on aaen black/orange spring. also, that spring is a short spring.
the yamaha spring that has same specs is the g/g/g spring, but its a tall spring. specs on that spring are 40/131kg--2.75kg rate.
YAMMIEGOD3:16 said:
JOSH, HAVE ANY SHIMS TO UP ENGAGEMENT LAYING AROUND YOUR NOT USEING. 3:16 (yammie tony)
You bet. What thickness you need? Also, I can make some of whatever thickness if needed. You got any gears/helixs/weights etc, that you're not using? Just pm me.
