B blue800 New member Joined Jul 10, 2007 Messages 69 Age 60 Location powers lake wi Nov 12, 2010 #1 any one know what yamaha spring would be close to this spring
Y YAMMIEGOD3:16 Active member Joined May 30, 2004 Messages 6,343 Location webster n.y. Nov 12, 2010 #2 I CAN TELL YA IF YOU HAVE SPEC ON THIS SPRING. 3:16 (yammie tony)
mopar1rules Active member Joined Jan 30, 2006 Messages 3,198 Age 40 Location manitowoc, wisconsin Nov 16, 2010 #3 40/130kg--2.75kg rate on aaen black/orange spring. also, that spring is a short spring. the yamaha spring that has same specs is the g/g/g spring, but its a tall spring. specs on that spring are 40/131kg--2.75kg rate.
Y YAMMIEGOD3:16 Active member Joined May 30, 2004 Messages 6,343 Location webster n.y. Nov 16, 2010 #4 JOSH, HAVE ANY SHIMS TO UP ENGAGEMENT LAYING AROUND YOUR NOT USEING. 3:16 (yammie tony)
mopar1rules Active member Joined Jan 30, 2006 Messages 3,198 Age 40 Location manitowoc, wisconsin Nov 17, 2010 #5 YAMMIEGOD3:16 said: JOSH, HAVE ANY SHIMS TO UP ENGAGEMENT LAYING AROUND YOUR NOT USEING. 3:16 (yammie tony) Click to expand... You bet. What thickness you need? Also, I can make some of whatever thickness if needed. You got any gears/helixs/weights etc, that you're not using? Just pm me.
Y YAMMIEGOD3:16 Active member Joined May 30, 2004 Messages 6,343 Location webster n.y. Nov 17, 2010 #6 PM YA. THANKS JOSH. 3:16 (yammie tony)
