Heya,
Ive found a service manual that im thinking of buying for Srx700, and it was printed in -99. However, my sled is from -01. Did they put out a service manual for every year of the Srx? Does that "old" manual apply to my sled also?
Just wondering if its worth the money.
ReaperSRX
Your manual is good for 98 & 99, i have the same but i have 2000 SRX and there are some differences in jetting, gearing, rear suspension specs etc.....however alot is the same, but it's easy to mix some things up.......James
well the complete wiring, ignition system, lighting,skid frame, carbs, jetting,clutching , cylinders,heads,carbs,are all differnt from 98-99 to 2000 , but the rest is the same....lol, if you get my drift, its the wrong book!!
I thought so. Well, someone else will probably enjoy it.Thanks
Adde
Junior
cylinders and heads the only difference is port height and clearance volume, and not by much
the electrical will be all wrong tho
oh really?? how about the dowel pins that hold the powervalve housings on? there is alot of things differnt from 98/99 to 2000-02. driveshaft,gears,chain,skid rails,cables,.........it goes on and on
