I need to replace the track in my sons 95,stock suspension and drivers.Can I go up to 1"?Also,does it matter about clips or closed windows? Thanks for any help.
1" should be fine. Might have to trim lugs if they cross windows at front heat exchangers. Open or closed wont matter, only matters when running extrovert drivers. I have one of each and no diff. CCC
Every third window will be more cost effective,, clipped every window will create a little more cooling for sled and save on hyfax a bit......... 1" would work fine....
Thanks,I found a nice used track.Does anyone know where I can get a 19t upper gear for this sled and will it make a worthwhile difference?Im thinkin while its apart....
