pinboy122
I need to replace the track in my sons 95,stock suspension and drivers.Can I go up to 1"?Also,does it matter about clips or closed windows? Thanks for any help.
super1c
Super Moderator
1" should be fine. Might have to trim lugs if they cross windows at front heat exchangers. Open or closed wont matter, only matters when running extrovert drivers. I have one of each and no diff. CCC
braindead1684
yep 1" fits easy and works GREAT!!!
Every third window will be more cost effective,, clipped every window will create a little more cooling for sled and save on hyfax a bit......... 1" would work fine....
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
We sell a 15 x 121 x .920 for $295.00 it is fully clipped. This track was made to replace the older sleds.
pinboy122
Thanks,I found a nice used track.Does anyone know where I can get a 19t upper gear for this sled and will it make a worthwhile difference?Im thinkin while its apart....
