Just cheking if this is normal i start it cold it revs up at like 2500 when cold then drops to 1500 rpm when warm?
YAMMIEGOD3:16
THATS PRETTY CLOSE. SHOULD IDLE AROUND 1800. 3:16 (yammie tony)
My SRX idlles at about 1500-1600 rpm regardless if its cold/warm or choke setting. When its cold i actually need to give it slight gass or it stalls. I guess its time to clean out the carbs?
TopGunnSrx
I set mine at 1600 I believe yami calls for 1800 +-100
Never hurts to clean the carbs, you've got nothing to lose.
