Srx stock idle rpms?
shock720
toronto
Just cheking if this is normal i start it cold it revs up at like 2500 when cold then drops to 1500 rpm when warm?
My SRX idlles at about 1500-1600 rpm regardless if its cold/warm or choke setting. When its cold i actually need to give it slight gass or it stalls. I guess its time to clean out the carbs?
I cleaned the carbs I just gotta set the idle and the choke cables back an wana make shure it's fine, but is it normal to start I up and it rev up past 2k then drop down in a few seconds?
