Brett Corwin
How much is to much compression in a SXR700 motor? I posted the compressin as 145-151lbs warm and with throttle wide open. In a garage at about 55 deg's, it was in there for a couple of hour prior to doing the test. Only 3 full pulls (throttles wide open) and we got 157lbs. to 161lbs on all 3 cylinders. I will check it with another gauge....
Until then is that to much compession? I'm not boasting about the compression! I'm worried about it being to high! I check the gauge then double checked it! I just want a good running sled with some get up and go! Reliable and fun thats all. The compession was that high when I bought it. The head is not cut, the jugs are and the exhaust ports are ported.
Piolet jets are 145.... do they need to be larger? I'm riding at around 1500' to 2200' elevation.
Should I cut the reed stops? There are carbon fiber reeds installed already. Should I go back to the stock reeds if I cut the reed stops??
Factory pipe and can. I cut the can as suggested by some of the members here.
Installing a Boost Bottle from Hauck and a clutch kit stage #3 from Hauck (set to my weight 280lbs with gear and aggressive trail riding style).
Please make suggestions. This is my first Yamaha and I really don't know the in's and out's with this sled!
Thanks all,
Brett
Thanks all,
Brett
