Putting all new bearings on the drive shaft of a 2001 SRX700 and seem to be missing a collar. The shaft has 8t extroverts (if that makes a diff). The OEM microfiche shows that there should be a collar on the axle (driver side of the chaincase bearing) which wasn't there when I tore down. Is there any reason why I wouldn't need it? Am I going to need to give Yamaha 26 bucks for a dang collar? I already ordered the 'all balls' bearing kit from royal distributing but doubt the collar is included in the kit.
For further clarity it is # 30 in the linked OEM Michrofiche
Chaincase parts
Thanks for your expertise.
Chaincase parts
Skidooslayer687
#30 in the micro fiche looks to be the collar the oil seal runs on? If in fact it is, it should already be on the drive axle on the chaincase side. I didnt realize that the collar was removable, but it does make sense if it is as you'll wear a groove into it over a period of time.
To answer your question, if it is the collar the seal runs on, yes you do need it or you wont be able to keep any oil in the chaincase.
I could be wrong on this, others will chime in if I am...
Good luck!
Good luck!
bluewho
Are you shure its not stuck on the axle?I think it is a stopper so the axle has something to bottom out on when tightening the gear bolt as well as a seal race!
cliffordtom
are you talking about the collers that touch the drivers if so you dont need them with extroverts
kirk700 srx
That is a bushing that spaces your gears to proper chain alignment. the small one goes on the bottom and the larger one goes on top if I remember correctly!! I am wrong here
kirk700 srx
sorry I never seen the O rings. that is a seal to keep the oil in and water out
kirk700 srx said:That is a bushing that spaces your gears to proper chain alignment. the small one goes on the bottom and the larger one goes on top if I remember correctly!!
Like mentioned above that collar is the surface the seal runs on. The O-ring seals it to the shaft (and also helps hold it in place). You should have that inplace, otherwise ice, snow, water and debris will get in your bearing and some oil will get out. It is likely on the driveshaft as the O-ring will hold it there when the chaincase is removed. If not on the driveshaft, did it fall off during disassembly? Hopefully it wasn't run without that in there.
This would likely explain things, the oil seal is there but no collar/bushing. The drive shaft was sliding side to side (through the bearing) and the bolt started to wear a hole in the chain case cover.
I just got the sled and didn't put many miles on last year. The previous owner who installed the extros must have forgotten to put it back in, or it broke out somehow.
Anyway, thanks guys.
Does anyone know where I can get OEM parts other than the stealership? The after market bearing kit was $30 if I had gotten Yamaha parts from the dealer it would have been a $100. So ridiculous!
bluewho
That sucks look around for a local wrecker or post in the wanted section.The top one is there right?
