the tree man
2000 SRX 700.Put in a new power valve last year to replace one that broke in half and had maybe 10 hours on it.It was already pulled half way through when I checked today and I had adjusted it slightly loose to begin with.I pulled out the other 2 and they are like brand new where the cable attaches(with 6500 miles).Turns out the new one does not have a steel sleeve in the cable slot and the others do.Those cable ends are under built to begin with considering the soft material in a valve.I drilled the end to 3/16" and put a short piece of steel 3/16" brake line in.Drilled the center to 9/64",cut the slot with a 1/32" zip wheel and bingo,perfect fit and bullet proof pull through prevention.I'm not sure if the other 2 were modified by someone else or were factory but at $167.00 a crack Yamaha should be doing it.
